This may be stupid, but…
I have a sheet with several Numeric columns for currency. I don’t use every column for every data row. But when I create a new row, all Numeric columns are auto-populated with $0.00.
Is there a way to turn that auto-population of $0.00 off?
I’d lean on a trigger formula
value if value else None
value or None
This is odd, thought - manually entering “0” is still allowed… which is good for our purposes I guess, but it puzzles me since “0 or None” is None.
Only if you tick the “apply on changes” box, then inserting “0” will result in “None”, as I expected.
This works perfectly. Thank you so much!
