Hi there,
I am hosting Grist on podman via a docker-compose.yml file, quoted below. I upgraded to 1.7.19 today, from 1.4.2. On this new version, when I click on any document on my logged-in home page, I see
for a URL
{https://}scicomp-grist.cs.illinois.edu/o/docs/dbQCKRwJRQEN/Numerics-Seminar
(Ignore the braces, I’m trying to hide the URL from Discourse wanting to expand it.)
The logs say this:
Sep 30 13:59:03 scicomp-discourse bash[1773055]: grist-1 | 2026-09-30 18:59:03.569 - info: DocWorkerMap.assignDocWorker dbQCKRwJRQENQXhtvU5nMq undefined
Sep 30 13:59:03 scicomp-discourse bash[1773055]: grist-1 | 2026-09-30 18:59:03.571 - info: DocWorkerMap.assignDocWorker dbQCKRwJRQENQXhtvU5nMq already assigned to testDocWorkerId_8484
A perhaps-related oddity is that the admin panel things I am running a sharded installation:
Every time I restart the service, another “server” gets added. NB: As you can probably tell from the compose file, there’s no actual sharding happening.
Any tips?
Thanks!
Andreas
services:
redis:
image: docker.io/redis
minio:
image: docker.io/minio/minio
environment:
MINIO_ROOT_USER: "admin"
MINIO_ROOT_PASSWORD: "****************"
ports:
- "127.0.0.1:9001:9001"
volumes:
- "/opt/grist/minio-data:/data"
command: 'minio server /data -console-address ":9001"'
grist:
image: docker.io/gristlabs/grist
environment:
GRIST_DEFAULT_EMAIL: "andreask@illinois.edu"
GRIST_SESSION_SECRET: "****************************************************************"
APP_HOME_URL: "https://scicomp-grist.cs.illinois.edu"
GRIST_SANDBOX_FLAVOR: "gvisor"
GRIST_FORCE_LOGIN: "true"
# GRIST_ORG_IN_PATH: "false"
PYTHON_VERSION: 3
REDIS_URL: "redis://redis"
# GRIST_DOMAIN: "scicomp-grist.cs.illinois.edu"
# Default should be OK
# GRIST_OIDC_SP_HOST: "https://scicomp-grist.cs.illinois.edu"
GRIST_OIDC_IDP_ISSUER: "************************************************************************************************************"
GRIST_OIDC_IDP_CLIENT_ID: "************************************"
GRIST_OIDC_IDP_CLIENT_SECRET: "****************************************"
GRIST_OIDC_IDP_SKIP_END_SESSION_ENDPOINT: "true"
GRIST_OIDC_SP_IGNORE_EMAIL_VERIFIED: "true"
# Old value
GRIST_DOCS_MINIO_ACCESS_KEY: grist
GRIST_DOCS_MINIO_SECRET_KEY: ****************
GRIST_DOCS_MINIO_USE_SSL: 0
GRIST_DOCS_MINIO_BUCKET: grist-docs
GRIST_DOCS_MINIO_ENDPOINT: minio
GRIST_DOCS_MINIO_PORT: 9000
ports:
- "127.0.0.1:8484:8484"
volumes:
- "/opt/grist/data:/persist"
