Hello, I am trying to write a formula with the following logic:
- check if a particular word (ie “mtd_sk”) is a selected value in the choice field named “Certs_Disa”.
- if the above condition is true, return the field value “EffectiveDt” (a date value) in the column.
The below code is the formula I wrote, but it is not working… any thoughts?
for cert in $Certs_Disa:
if cert.lower == "mtd_sk":
return $EffectiveDt
You need to call the method: cert.lower()
You say Certs_Disa is a choice field, which can only contain one value. I assume you mean choice list? If not, you shouldn’t use a loop at all, you’re actually looping over individual characters of a string.
Either way, you should know the exact value of the choice, e.g. "Mtd_Sk", unless somehow you have multiple configured choices which differ only in case (which sounds dangerous), or the cell can contain invalid choices. In that case you can simplify your formula to something like if "Mtd_Sk" in $Certs_Disa: depending on the correct value and assuming $Certs_Disa is a choice list.
Thank you. I understand the danger of multiple choices which differ in case… as well as the low likelyhood of mistakenly adding a value … was just being OCD.
rookie mistake of failing to call the function by ending in “()”.
Anyway, I will take your suggestion of simplifying the formula to:
return $EffectiveDt
The whole formula can just be:
return $EffectiveDt
The in means you don’t need a loop, since you’re not using cert.
For all posterity… i left off the “:”
corrected version
return $EffectiveDt
