Using Grist on a static website
I made a proof of concept of showing Grist documents on a static website without any special back-end support:
Normally Grist documents are hosted on a special server, which does all the computations and makes sure that edits by one user are seen by all. With grist-static, the computations and edits are moved into your browser, all the server does is provide assets (.html files, .js files, .css files, images, and now .grist files :slight_smile: ). If you have a scenario where you don’t need to save changes or share them between users (for example, if the Grist doc is some deliverable like a report or piece of analysis), then skipping the special server might be actually desirable, to have everything under one roof.
I’m not sure if anyone actually needs such a thing (regular Grist embedding is probably what you want usually) but it was a fun experiment! Seems to work fine on up-to-date Chrome, Firefox, and Safari.
That’s so cool!
I see so many use cases for this and will try to use it when i have to publish data in the future!
One can still use &embed=true with this btw, so it could be inlined nicely into a report or publication.
As I said earlier Grist + Seaborn library my wife was making a presentation on her project, the input data for which she prepared in Grist.
She took dozens of screenshots of data widgets.
The presentation was not conducted by her, but by the head of her project.
@paul-grist I think that this solution would be perfect as a presentation. You just need to pack it into one executable . exe
It is in this case &embed=true not suitable, bcs we need set access to public and formulas are the result of her work. At the same time, everyone can see the calculation model.
This is really fantastic. We are using this to offer free tools related to our domain. You can see examples of Contract Management Spreadsheet, Entity Management Spreadsheet, and Business Ownership Spreadsheet.
We even made YouTube videos demonstrating how to use these great spreadsheets. See the Watch Demo links on those pages.
2 suggestions related to the singlePage: true option:
  1. Right click on column heading still shows “Column options” but the column options does not open.
  2. Would be nice to still have the ability to download the entire grist file as an XLSX instead of just the individual tables one at a time.
Still, nice work!
I’m getting the below error whenever I try to load an actual Grist file:
Is that an internal domain? Can you check the dev console in your browser for access errors? Security can be pretty tight. Internal Server Error also I assume is coming from whatever you’re using to serve the Grist js/html/css files since in this setup Grist itself doesn’t have a server?
I will check on that. Thank you, Paul.
We are using IIS, that isn’t an issue is it?
That’s fine. But, given that error message and just guessing, it is possible you need to tell it somehow that it is ok to serve a file with the .grist extension.
@paul-grist Hi Paul. Does the initialFile attribute works with a CDN HTTPS URL that is password protected?
Password protected in what sense? Do you mean a signed URL, HTTP Basic Auth, a CDN resource that requires authenticated cookies/tokens, or something else? Stepping back: if you have your own javascript code to fetch a file, then there should be a way to render that. If it is CSV or some importable format then initialContent should work.
I was thinking to use XmlHttpRequest or the Fetch API, like using curl, to retrieve a .GRIST file from a CDN using an access token.
Something like this should work:
const resp = await fetch(FILE_URL, { headers: { Authorization: 'Bearer ' + token } });
const bytes = new Uint8Array(await resp.arrayBuffer());
bootstrapGrist({ initialFile: bytes, name: '...' });
