WEBINAR: Custom Widget Builder - December 19, 2024
In December, CTO Paul and Software Developer Jarek shared their Grist Summit talk on Grist’s custom widget builder. Learn from the devs themselves how to create your own custom widget, step-by-step!
Timestamps
01:18 An overview on widgets
04:16 Intro to custom widgets
06:46 :white_question_mark: User Question: Can you make an API call from a custom widget? (:white_check_mark: Answer: Yes!)
09:09 Demonstration: Creating a color picker widget using the Custom Widget Builder
13:38 Configuring widget access to the document
14:20 Configuring linking with other widgets
16:53 Configuring ability to write changes to data into the data table
17:03 Tip: Save often!
21:07 Configuring ability to read changes to data from the data table
24:43 :white_question_mark: User Question: Can we access data from all other tables?
26:19 :white_question_mark: User Question: Can we change the cell color based on the color selected in the picker?
27:21 The Levels of Widgetness
31:02 Configuring column mappings
39:10 Custom configurations
41:40 Premade Custom Widget Gallery
53:11 :white_question_mark: User Question: Can you create rows from the custom widget? (:white_check_mark: Answer: Yes!)
Links
Document Shown
