Working with dates in access rules
Hello.
I have a column with dates. I need to make it so that editors cannot change a row if the month of the date is 2 less than the current month, that is, I need to disable editing of previous periods.
In access rules, you cannot use functions for working with dates like: NOW() > DATEADD(rec.date, montns=2)
How else can I be prevented from editing old rows in the table?
Make a formula column that does whatever calculation you need with dates and returns true or false. Then just check that column directly in your access rules.
