I’m thinking about using Grist internally.
What is the best way to deploy Grist : docker or yarn ?
I’m thinking of developping some custom widget and I’m not so familiare with docker…
What are the cons and pros ?
I’m not going to comment on Yarn vs Docker, but note that developing custom widgets is a separate issue. Custom widgets can be hosted anywhere and don’t need to be connected to a Grist deployment. You can develop a custom widget now and use it from documents on getgrist.com.
