Hi -
Could a ‘combo chart’ be added as a charting option - i.e. a column and line combo? It would be really useful to be able to plot 2 series on a chart with a dual axis.
Hi -
That would be a great feature! I’d use it too. Added it to feature requests. Thank you.
In case you haven’t seen the announcement, you can now use the new Advanced Charts custom widget for more flexibility. In particular you can add two ‘traces’ (one bar and one line) for this situation.
