Real-life example
SQL widget implements a basic SQL selector widget thanks to the new SQL endpoint. The URL to use it as a custom widget is: https://jperon.github.io/grist/sql/dist/
; the source is available here.
There is a sample page making use of it here.
You may try, for example:
select distinct v.id
from 'Values' v, 'Labels' l
where v.Labels GLOB '*[^0-9]'||l.id||'[^0-9]*'
and l.Label in ('Third', 'kkk')
Install dependencies
Transcrypt
- Install Python 3.9 (at the moment of writing, as it’s required by Transcrypt 3.9): cf. your system’s doc
- Create a folder for your project:
mkdir my_widget && cd my_widget
- Within this folder, create a new Python venv:
python3 -m venv py
- Activate this venv:
source py/bin/activate
- Install Transcrypt:
pip install transcrypt
Parcel.js
(Assuming you’re still within your project’s folder with your venv activated.)
- Install Parcel.js:
yarn add --dev parcel
- Create a
.parcelrc
file with this content:
"extends": ["@parcel/config-default"],
"transformers": {
"*.py": ["parcel-transformer-transcrypt"]
Create your widget
Create those two files in your project’s directory. We’re taking the same onRecord
example as Grist’s documentation.
index.pug
Learn X in Y minutes gives the basics and references to documentation.
doctype html
html(lang="en")
head
meta(charset="utf-8")
title onRecord
script(src="https://docs.getgrist.com/grist-plugin-api.js")
body
pre#readout Waiting for data...
script(type="module" src="index.py")
index.py
We’re using document.querySelector
instead of document.getElementById
here: it shows that pug’s syntax makes it very easy to identify how to select elements.
grist.ready()
grist.onRecord(
lambda record: document.querySelector('#readout').innerHTML = JSON.stringify(record, null, 2)
Launch Parcel.js
yarn parcel index.pug
will automatically download required JavaScript packages, prepare files and serve them. It’s then possible to define a custom widget on Grist, using http://localhost:1234/
(by default) as URL. The widget will automatically reload every time the files are modified.
Once development is finished, yarn parcel build index.pug --public-url ./
will produce files suitable for production in the dist
folder, that should be put online.
From then on, every time one works on the project, the only steps are activating the venv and launching Parcel:
