Formulas based on absence/presence of attachment
Hey all!
Hoping to have a toggle automatically switch to “on” if/when an attachment is added to an attachment column in the same table. I understand how to use trigger functions, but am not sure on how to incorporate the attachment column into that at all. Is there a true/false or equivalent connected to attachment columns?
Any guidance (including telling me this may not be possible atm) would be appreciated!
Cheers,
Parker
Hi Parker. Welcome to the forum!
You can use the bool() function in a formula column to return whether or not an attachment column has a value (i.e. an attachment).
bool($AttachmentColumn)
Hope this helps!
I knew there must be some sort of easy solution here! Thanks so much :slight_smile:
