I have a formula column where column type is choice; where the values are being combined from other two columns. Though the value shows correctly but appear with red-border. To fix this I need to add the exact value manually as a “Choice”. Is there a way not to do this manually?
You’ll need to insert the values both into the actual data and into the column’s list of valid choices. The latter part requires a more sophisticated formula, but I just happen to have one lying around in the RUC.
Take a look at the ‘WidgetOptions.add_choice()’ function in here. This function takes a ‘colrec’ as an argument, you can obtain such a ‘column record’ by using ‘Column.get()’ from here.
That should do the trick. Let us know how it goes!
