What’s new
GristCon speakers and sessions announced!
Have you signed up for GristCon yet? Our one-day virtual community conference is quickly approaching – Thursday, September 18, 2025 – and we’ve just released details on the 10 planned sessions, hosted by Grist Labs employees and members of the community from all over the world. Take a look – we’re sure there’s something that will catch your eye.
Duplicating widgets
At Grist Labs, we remain DRY at all times. We hate duplicating data so much we built a bunch of software designed around not doing it! Thankfully, duplicating widgets – which you can now do – does not duplicate data, but instead saves you time having to recreate layouts and formatting.
Increased Assistant functionality
There’s been another round of updates to the Grist AI Assistant. It can now:
- Create, rename, or remove pages, as well as add, update, and remove most widgets in pages.
- Add custom widgets by URL.
- Create summary tables from specified
GROUP BYcolumns for new widgets. - Link widgets on the same page.
More Grist updates
- There’s an experimental (and quite minor) “Add new record” button that is always visible and makes it easier to add new records. You can test this button out by appending the URL parameter
?experiment=newRecordButton. Please share your feedback with us on Discord!
- Emmanuel Pelletier’s accessibility work continues to improve Grist, and this month we welcome a handful of shortcuts to make keyboard navigation useful outside of tables:
Ctrl/Cmd + O,Ctrl/Cmd + Shift + OandAlt + Ctrl/Cmd + O.
- If you’re self-hosting, you can now add extra truthy/falsy values to your Grist instance using the delightfully-named environment variables
GRIST_TRUTHY_VALUESandGRIST_FALSY_VALUES! You control the fabric of reality – use this power wisely!
The new 1.7.0 release of grist-core includes a very handy change that will be live on Grist everywhere soon: saving page collapsed state!
See the full release notes on GitHub.
Community highlights
- Thanks to scytacki for adding the
NETWORKDAYS()function (“net workdays” not “network days”) and string support toDATEDIF()in their recent PR. - If you’re interested in generating PDF reports in Grist, be sure to check out aude’s detailed walkthrough of how they generate elegant French letterhead with table data and nothing else.
- Varamil has shared an update to their full-featured Kanban widget.
- Over on le forum Grist, raphael has shared a very nice looking Grid custom widget which acts as a simple display-only pivot table with support for linking!
- Edouard_Morin adds to the list of Grist API packages with a very welcome addition: R! Check out their post in the Community Forum for more info.
Learning Grist
Ongoing Grist 101 webinars
SIGN UP FOR A GRIST 101 WEBINAR
Webinar - Grist Secrets
Think you know everything about Grist? Think again!
Whether you’re a beginner or a seasoned user, you’re bound to discover something new in this month’s webinar where we dive into corners of Grist that are as helpful as they are obscure. From handy shortcuts that save you time, to underused features for customizing Grist even further!
Join us to uncover the not-so-secret secrets of Grist!
Thursday August 21 at 11:00am US Eastern Time.
Community Custom Widget Showcase
In June, Natalie showcased some of the custom widgets shared by our smart and talented community. We took a look at the HTML table & access rule report generator, draw.io viewer & editor and a Batch Email Composer. Get a behind-the-scenes look at how these widgets extend Grist in useful and surprising ways – perfect for anyone curious about what you can build with Grist.
